Duik Run Script Erros
Alexandra Nel
on Aug 14, 2017 at 7:13:44 am
Hey
Ive installed Duik and Ive used the installer, Ive also done this manually in my troubleshoot process. Both resulted in the same error. I am using AE CC17 and the latest version of Duik (15). I doing this all on MAC.
After I install and go to run the script in AE I get bombarded by a zillion error messages stating that every individual .png cannot be located- after I get through all of this the script cannot run. Im not too sue how to get around this, Ive restarted everything, uninstalled and reinstalled multiple times....eventually DUIK installer stopped reading my current version of AE and I had to indicate where it was manually- after which it could not write the ScriptUI folder....so things got from worse to horrific really... mainly i just need help with this .png error.
I did notice that there is a .exe file for PC in the downloaded files from DUIK which is a bit perplexing
