Render Fail - Consistently at 28 frames
Lindsey Gullett
on Aug 1, 2017 at 10:00:48 pm
I'm rendering out a large file with several different effects involved in it. The video is :43 seconds long, but I'm consistently getting a "Failed render" with no fail report at 28 frames in. I tried adjusting my timeline to render starting past this point, to see if I could bypass a potential bad frame or file, but the render is still failing at 28 frames. Has anyone had this happen to them? I'm at the end of my rope for ideas. Thank you in advance.
Remus Hosu
Re: Render Fail - Consistently at 28 frames
on Aug 2, 2017 at 6:18:51 pm
Hi Lindsey,
I think your safest bet is still with the secret menu. Make sure you have the Disable Layer Cache checked and try to set the purge value to 1. It should give you the maximum amount of memory for every frame. Here's an article on this (the video is locked but just click "read more" below it)
https://bluefx.net/course/render-in-after-effects-the-right-way/secret-pref...
Lindsey Gullett
on Aug 11, 2017 at 2:15:03 pm
**Solution (sort of): After dealing with Adobe and Video CoPilot support directly, it was determined that one of my large assets that I had Twitch activated on was causing the issue. There's not really a solution to this other than just turning Twitch off of the asset. They declared that it was eating up too much RAM while rendering and causing it to fail. They said that this does happen at times. Not necessarily the solution I wanted to hear, but at least I found the source of the problem.
Thanks to those who chimed in with their suggestions.
