Tie/un-tie rope
Geoffrey Amend
Tie/un-tie rope
on Jul 29, 2017 at 6:20:28 am
I need to tie a knot or two in a rope and then untie it. Looking for any ideas. I made a rope brush in photoshop that I was going to use as a path and then perhaps the boa plugin. Or paint and stick. But came across this sample that is perhaps a reference point.
https://vimeo.com/58405128
Any other ideas or tutorials? Thanks.
Thank you!
Dave LaRonde
Re: Tie/un-tie rope
on Jul 29, 2017 at 5:26:04 pm
Unless you enjoy driving yourself stark-raving insane, forget about doing this in After Effects. Do it in a 3-D application. Even then it won't be fun. Half-hitch, Clove Hitch, Square... doesn't matter. Knots are about as much fun as making photorealistic hair wave in the breeze.
Dave LaRonde
Promotion Producer
Geoffrey Amend
Re: Tie/un-tie rope
on Jul 31, 2017 at 1:42:15 am
As usual that is incredibly helpful.
Thank you!
Steve Bentley
Re: Tie/un-tie rope
on Jul 31, 2017 at 1:21:13 pm
Boa will do the job - does it have to look like a rope? The indents at the edges might be tough where the grooves between wraps are. I haven't tried this but you could make a copy of your main "rope" and increase the spacing and make this second rope a little smaller so the "balls" of the brush that makes the shape of the spline barely overlap are the width of the first rope at the edges of the balls only. Use this second spaced rope to mask out the first boa object - when you get the spacing right it might line up with your rope wrap texture and voila, edge bumps.
Depending on how you want the ropes to move (other than just growth along their length) you might have to combine boa with a few other scripts available at the same place to get proper easing control of the spline control points.
And depending on your realism requirments you may have to cheat to get the overlap shadows by adding a masked soft or hard edged element within the rope shape itself.
Doing this in 3D would be easier but unless you want to go with a collision dynamics system you have the whole problem of intersecting geometry which can detract from the realism - shadows would be solved but again you have the issue of point level animation for the spline points. But you can always conscript some nulls and animate them and have their positional data control the spline points. This will give you the easing you can't get from PLA.
Geoffrey Amend
Re: Tie/un-tie rope
on Jul 31, 2017 at 4:01:03 pm
Thank you. I'll have a look.
Thank you!
