After Effects CC Preview Frozen??
Alexander Morrison
on Jul 26, 2017 at 10:13:00 pm
I'm currently extremely confused and very irritated. I have Adobe After Effects CC 2017, and at least once every minute, the program will stop producing previews and will halfway freeze. I can still interact with the buttons, move things around in the comp, and I can even see the little indicators of object locations, like the edges of 3D planes I've tracked in or things of that nature, and move those around, but I can't see the result until it unfreezes, which happens anywhere from 30 seconds to 10 minutes later. I've ruled out using too much processing power on either my GPU or CPU, as it will happen even if I have a completely empty comp.
Dave LaRonde
Re: After Effects CC Preview Frozen??
on Jul 27, 2017 at 3:22:16 pm
Purge all memory & caches. See what happens.
Dave LaRonde
Promotion Producer
Icaro Gabriel
on Oct 23, 2018 at 2:05:17 pm
Im having the exact same problem.
Found a fix?
