Shape layer Rectangle path time duration and size control by slider
Arun Chaudhary
on Jul 26, 2017 at 11:24:22 am
Hi all
How to Shape layer Rectangle path time duration and size control by the sliders
I'm using two sliders 1 for time duration and 1 for Percentage Value
I use this expression but it is not work as we want
m = thisComp.layer("Animation Duration").effect("Animation Duration")("ADBE Slider Control-0001");
h = thisComp.layer("Values").effect("Percent Value")("ADBE Slider Control-0001");
linear(m,0,100,[0,150],[h,150])
The main problem is Shape layer Rectangle size is x=1800, y150 so y is fixed but "x" control by slider
slider value is 0 X value 0, slider value 100 x value 1800
I attached a screen shot for better understand
Thank you
Andrei Popa
Re: Shape layer Rectangle path time duration and size control by slider
on Jul 27, 2017 at 10:17:31 am
try this
h = thisComp.layer("Values").effect("Percent Value")("ADBE Slider Control-0001")*18;
linear(time,0,m,[0,150],[h,150])
Andrei
Arun Chaudhary
on Jul 28, 2017 at 6:28:27 am
Hi Andrei Popa than you for reply but
unfortunately, this does not work for me I attached ae file for better understud
Thia is a Progress Bar so count 0 to 100 by slider you can see ae file than clear all think
https://www.dropbox.com/s/t6oqe6hmruus1io/Progress%20Bar.aep?dl=0
Andrei Popa
on Jul 28, 2017 at 2:46:17 pm
I don't quite understand what you want to do, but i see this as potential problems:
If you want your pink rectangle to grow with the keyframes, use this expression on the size of the rectangle
m=thisComp.layer("Animation Duration").effect("Animation Duration main bar")("Slider")
linear(m,0,100,[0,150],[1800,150])
If you want the text to grow as the rectangle grows, use this expression on the text source
Math.floor(thisComp.layer("Animation Duration").effect("Animation Duration main bar")("Slider"))+"%"
Maybe change the color so the bar si different.
If you want the text to grow with the first bar, use this expression on the source text
Math.floor(thisComp.layer("Animation Duration").effect("Animation Duration BG CR")("Slider"))+"%"
Now, if you decide to stop the rectangle an some percent, both the text and the rectangle will act accordingly.
Otherwise, you will have to explain better your problem.
All the best
Andrei
