RAM Preview not updating
Ocean Byrne
on Jul 21, 2017 at 9:41:26 pm
I'm having some strange issues where I've done a ram preview (at quarter res and every other frame), and then I make a modification that affects say 20 frames in the middle, and I click ram preview again and it just plays me the last preview without updating anything. The only way I have found to get it to update is to Purge>Everything, but then it has to re-preview all the other frames as well as the ones that need updating.
To add to the confusion, it isn't consistent. Sometimes it updates fine. It seems pretty prone if the edit is inside a precomp, but some times it happens on the main timeline too (which is set Always Preview This View).
Any ideas?
Walter Soyka
Re: RAM Preview not updating
on Jul 23, 2017 at 11:54:23 am
Are you using third party plugins? If yes, are they up-to-date?
Walter Soyka
Chris Orcfilm
on Sep 23, 2018 at 2:16:29 am
Great clue Walter! I looked at the effects that I had attached to the layer and it was Mocha VR. When I disabled the effect (didn't even need to remove it), the preview started updating again as expected.
Thank you! Hope this helps someone else too!
Chris
BC Canada
