Remove all shape layers in selected composition
Arun Chaudhary
on Jul 21, 2017 at 2:31:01 pm
After effects, script remove all shape layers in selected composition
any idea? how can do this
Thanks.
Jim Scott
Re: Remove all shape layers in selected composition
on Jul 21, 2017 at 6:06:12 pm
I don't know how to create a script, if that's what you're asking, but if you just want to remove all shape layers: Enter "shape" in the search window above the layers in the Timeline panel. Drag to select them all (don't use "select all")... delete. Clear the search window by clicking the X and the remaining layers will be displayed.
Arun Chaudhary
on Jul 22, 2017 at 4:55:37 am
Thank you, Jim Scott, for your reply but this is not work in my case i have 500 hundred + comp. so I don,t want open all 1 by1 I want select all comp run script then removed all shapes layer in comp.
Walter Soyka
on Jul 23, 2017 at 11:50:32 am
Here's a quick script that will remove all shape layers in the selected comps in a project (or in the active comp if no selection is made).
Back up your project file first and use this at your own risk!
function deleteAllShapeLayersInComp(comp) {
// delete all shape layers in the specifed comp
// step through the comp, removing any shape layers as we go
// work backwards from the last layer, because removing later layers won't affect the indices of earlier ones
for(var i = comp.numLayers; i >= 1; i--) {
if (comp.layers[i] instanceof ShapeLayer) comp.layers[i].remove();
function processProjectSelectionComps(func) {
// go through all selected items in a project. if they're comps, perform the specifed function on them
if (app.project.selection.length > 0) {
for (var i = 0; i < app.project.selection.length; i++) {
if (app.project.selection[i] instanceof CompItem) {
func(app.project.selection[i]);
app.beginUndoGroup("Delete All Shape Layers");
processProjectSelectionComps(deleteAllShapeLayersInComp);
} else if (app.project.activeItem instanceof CompItem) {
deleteAllShapeLayersInComp(app.project.activeItem);
app.endUndoGroup();
Walter Soyka
Arun Chaudhary
on Jul 26, 2017 at 6:10:29 am
Hi, Walter Soyka
I want to say you are legends you make my day you script work fine as I want
Thank you so much
Arun Chaudhary
Remove all files in a shape layer and add stroke
on Sep 14, 2017 at 1:26:17 pm
again I need your help I find a post for Remove all files in a shape layer, John Colombo script works fine for active comp. but I want this script works for selected comp. in a project
and add a stroke in all shape layer stroke width can be set. if it is possible
https://forums.creativecow.net/thread/227/30520
I am very grateful to you
Arun
