There is animation but no visible keyframes
Mohsin Khan
on Jul 16, 2017 at 5:56:22 am
I have recently downloaded an after effects project for stomp typography. I can see the animation going on but when I press U, there are no keyframes visible. Also there are many effects on all the layers but they aren't visible under effects control tab. What am I missing here. I want to know about it and how can I reveal the keyframes and the effects,
Walter Soyka
Re: There is animation but no visible keyframes
on Jul 17, 2017 at 1:59:32 pm
U should show properties with keyframes, but with precomposing, parenting, and expressions, you could miss a lot. UU will show all properties which have been modified from their defaults. This will at least include properties with expressions, but not keyframes.
Walter Soyka
Remus Hosu
on Jul 18, 2017 at 9:53:58 pm
Most likely they have no keyframes but expressions. You can press EE to bring down the expressions
On another note, if you're intersted in placing the text layers on a motion path, there's a trick to reveal the "invisible" keyframes. See the tutorial here:
https://bluefx.net/capture-invisible-keyframes-motion-path-shape-layer
http://bluefx.net
