Select 100 random layers?
Don Jobs
on Jul 13, 2017 at 10:30:31 am
I have this script and it selects random number of layers:
function selectLayers() {
var myLayers = myComp.layers;
min=1;
max=myLayers.length;
var myRandom = new Array();
for (i=1; i <= myLayers.length; i++){
myRandom[i-1] = Math.round((max-min)*Math.random());
myLayers[i].selected = false;
for (j=0; j <= myRandom.length-1; j++){
myLayers[myRandom[j]].selected = true;
selectLayers();
How can I make it to select only 100 random layers?
Thank You very much for your help! ☺
Regards!
Mike Abbott
Re: Select 100 random layers?
on Jul 13, 2017 at 3:13:59 pm
6th line down:
change to:
for (i=1; i <= 100; i++){
http://mikeabbott.info
http://vantagegraphics.co.uk
Walter Soyka
on Jul 13, 2017 at 4:49:32 pm
Here's how I would approach it:
function randomIndexSequence(numIndices) {
// create a blank array
indexArray = [];
// fill the array with all the values from 1 to the numIndices argument to this function
for (i = 0; i < numIndices; i++) indexArray.push(i+1);
// shuffle the array by stepping through and swapping the value at each sequential position with a random position
for (i = 0; i < indexArray.length; i++) {
j = Math.floor(Math.random() * indexArray.length);
swap = indexArray[j];
indexArray[j] = indexArray[i];
indexArray[i] = swap;
return indexArray;
function selectRandomLayers(layers, numLayers) {
// get shuffled list of layers
shuffledLayers = randomIndexSequence(layers.length);
// step through the list of shuffled layers, and select the first n layers in that list, where n is the numLayers argument passed to this function
for (i = 0; i < numLayers; i++) {
if (shuffledLayers[i] <= layers.length) layers[(shuffledLayers[i])].selected = true;
myComp = app.project.activeItem;
selectRandomLayers(myComp.layers, 100);
Walter Soyka
Don Jobs
on Jul 13, 2017 at 7:38:18 pm
I love you guys!!!
This is beautiful!
Thanks a lot! :)
Don Jobs
on Jul 14, 2017 at 10:34:04 am
I have one more issue please ☺
Now I see that it works with all the layers in the composition including layers with the Shy switch On (Invisible in the list)
I would love to make it work with only visible layers in the composition list.
If it's too much work, this is already perfect!
Thanks again!
Walter Soyka
on Jul 14, 2017 at 2:30:17 pm
Instead of building an array of all the layer indices to shuffle, let's build a list of only non-shy layer indices. Then we'll shuffle that:
function shuffleNonShyLayerIndices(layers) {
indexArray = [];
// add each non-shy layer index to the array
for (i = 1; i <= layers.length; i++) {
if (layers[i].shy == false) indexArray.push(i);
// shuffle the array of non-shy layer indices by stepping through and swapping the value at each sequential position with a random position
return indexArray;
// get shuffled list of layer indices
shuffledLayerIndices = shuffleNonShyLayerIndices(layers);
// step through the list of shuffled layers indices, and select the first n layers in that list, where n is the numLayers argument passed to this function
for (i = 1; i <= numLayers; i++) {
if (shuffledLayerIndices[i] <= layers.length) layers[(shuffledLayerIndices[i])].selected = true;
Walter Soyka
Don Jobs
on Jul 14, 2017 at 2:55:09 pm
Dear Walter,
thank you very very much!!!
I was really stuck and now I can proceed with my project...
It's working!!! (Off course ;))
Thanks again!
