"Wiggle It" script not installing
Andrew Eisenhauer
on Jul 13, 2017 at 1:29:12 am
The script that I downloaded, from a design website, of good, professional reputation will not appear in the After Effects "Window" menu. After following the installation instructions, placing the files in the "ScriptsUI Panels" folder, I restarted AE and had no "Wiggle It" option. I have just downloaded this script, and this is the first time I have downloaded one. Any help?
Jim Scott
Re: "Wiggle It" script not installing
on Jul 13, 2017 at 5:15:27 am
If you have installed the two files -- Wiggle_It.jsxbin, and the (Wiggle_It_Resources) folder -- and enabled "Allow Scripts to Write Files and Access Network" in Preferences > General (check the box), you should have the script available. Assuming those are all done and it still doesn't appear, I would suggest contacting EJ at eyedesyn for assistance.
Good luck.
