Query an area within a comp
Chris Kay
on Jul 7, 2017 at 6:01:10 pm
Hello all!
Not sure if this should be in the general After Effects support, Expressions or Techniques. Anyways...
Trying to query an area within a comp and to get the color data(like the RGB or # value)
Currently, I'm trying to use a solid colors within a comp, then depending on the captured color, it will create a value i can plug in to something else. Like a time re-map value.
Theoretical example: On a Time Remap attribute
x=0;
C=Get RGB value from comp window;
if(C== "255,0,0")
x=.1;
[x]
Basically, I have an image sequence of just solid colors that change very quickly. I am trying to capture each color and convert it to a value which will then plug in to a layer with a Time Remap attribute. Sort of like "triggering" a specific time/frame from the color value.
Hoping this all makes at least some sense.
Thank you to all for any help.
Walter Soyka
Re: Query an area within a comp
on Jul 8, 2017 at 1:22:09 pm
Use sampleImage()
Here are a few examples from the incomparable Dan Ebberts:
http://www.motionscript.com/design-guide/sample-image.html
http://www.motionscript.com/design-guide/obscuration.html
Walter Soyka
