After Effects CCSphere issue
Radoman Radovic
on Jul 5, 2017 at 11:32:11 am
Hello there. I have an issue with CCSphere plugin. When I scale up radius of the sphere, it kind lowers the resolution. Also when I apply some wipe transision before CCSphere, to make sphere slices, edges become weird. I repeat, this is case only when I increase the sphere radius. Since CCSphere is not camera-aware plugin, can this issue be solved? Thanx in advance.
Radoman Radovic
Re: After Effects CCSphere issue
on Jul 5, 2017 at 2:27:59 pm
I figured it out. DO NOT use solid, or shape to build CC Sphere on. Use simple high resolution *.ai Illustrator file with simple rectangle in it. Weird...
