3D text template - able to change size but not position
Jules Thia
on Jul 1, 2017 at 11:58:53 am
Hi Guys,
I appreciate every tip and thank you for your help in advance.
I'm having a problem adjusting the position of the text for the following template:
http://www.mediafire.com/file/b62js5g5ert5kg3/Movie+Pack+%28Spiderman-Guard...
I've tried to unpack all the layers and adjust each setting individually but only managed to change the size of the text but not the position.
I've attached two images to illustrate what I'm trying to achieve.
I'm a beginner here so I'd certainly appreciate any help I can get. Thank you.
Cheers,
Jules
