Copy keyframe data from AE to Premiere Pro?
Harris Majeed
on Jun 29, 2017 at 4:36:14 pm
Hello everyone.
Is there a way to copy keyframe data from AE to Premiere Pro?
Specifically; i'm trying to position keyframes. I tried saving the AE project as a Propj file but apparently it was saved in a newer version of Premiere Pro?
Cheers!
alex ezorsky
Re: Copy keyframe data from AE to Premiere Pro?
on Jan 7, 2019 at 3:26:04 pm
You can copy keyframes from AE to PR! You can't do it by copying and pasting the keyframes or properties (like you could in AE or PR) BUT you can copy entire clips from AE into PR! If the effects/properties you have in AE also exist in PR they will carry over with it!
I was so pleased when I found this out via the famous Jarle at https://premierepro.net/jarles-premiere-pro-presets-version-4/
Amir Aizat
on Mar 13, 2019 at 2:16:04 pm
Hey Alex, that's a great help, I didn't know we can do that.
There's a problem with the Scale keyframes though, any ease applied in After Effects won't be imported (but the keyframes itself were imported). Do you know a way around this? I tried exporting as a Premiere Pro project in After Effects as well, but it gave me the same result.
It's a shame, it worked really well with Position and Rotation, but not Scale or Opacity.
Michael Szalapski
on Mar 13, 2019 at 2:21:58 pm
Try saving your titles from Premiere Pro as PNGs and then animate them in AE.
- The Great Szalam
