motion tile issue
Martin Robbins
motion tile issue
on Jun 26, 2017 at 6:21:11 pm
Hopefully one of you people can help me out here.
I am using motion tile to create a continuous road as if a car is driving, the perspective is as if from the drivers view. The car needs to pull over to the side of the road, to do this I used time remapping for slowing down and two position keyframes to move sidewards.
All looks good in After Effects but when I try to export, the motion tile effect that gives the effect the car is moving, suddenly stops when I get to the timeremapping/position keyframes. I have tried various ways of pre-comping, swapping the position keyframes for motion tile - tile center keyframes,... but no luck.
Any suggestions?
I'm using CC 2017.2 on a mac pro, OS X Yosemite, processor 3ghz 8 core, memory 64gb, graphics AMD firepro d500.
Look forward to hearing from you.
