How to preview videos in realtime?
Harris Majeed
on Jun 26, 2017 at 1:46:53 pm
Hello everyone. I am stunned by the capabilities of After Effects and i feel like moving on from Premiere Pro to AE, the main reason i'm moving is because of AE's tracker feature that i absolutely need.
But there's one problem, how do i view my videos in realtime like Premiere Pro? It's impossible for me to casually edit if After Effects gives me this problem. I dearly hope that there's a solution.
Cheers!
Walter Soyka
Re: How to preview videos in realtime?
on Jun 26, 2017 at 2:24:50 pm
[Harris Majeed] "how do i view my videos in realtime like Premiere Pro? It's impossible for me to casually edit if After Effects gives me this problem. I dearly hope that there's a solution."
Ae is not a non-linear editor, and it is not built for real-time playback. Rather than look to move wholesale from Premiere to After Effects, I think you should look at how you can use the two applications together.
Here are some links to get you started:
https://helpx.adobe.com/premiere-pro/using/dynamic-link.html
https://helpx.adobe.com/premiere-pro/how-to/dynamic-link-workflows-aftereff...
https://helpx.adobe.com/premiere-pro/using/render-replace-effects-compositi...
https://helpx.adobe.com/premiere-pro/how-to/integration-after-effects.html
https://helpx.adobe.com/premiere-pro/atv/cs6-tutorials/send-work-from-premi...
Walter Soyka
Harris Majeed
on Jun 26, 2017 at 3:42:07 pm
Thanks, Walter!
I actually knew about Dynamic Link but thought there would be a way to use AE completely. Oh well, it's not the end of the world. I can use Dynamic Link.
Again, thanks for the response.
