continue evolution through multiple compositions
Miro Nauces
on Jun 23, 2017 at 2:44:36 pm
I have more compositions, all of them use a precomp with solid layer and some evolving color effects on it. What I need is to have the effect to progress in each following composition. Now the effect just starts from beginning with every composition.
I tried to set up effect controls on main composition and automate there, but the result is same.
Is there any simple solution to this? Thank you.
Michael Szalapski
Re: continue evolution through multiple compositions
on Jun 23, 2017 at 4:28:03 pm
Make your source precomp longer and then just offset the time of its layer in each of the comps that use it.
- The Great Szalam
Miro Nauces
on Jun 23, 2017 at 4:38:37 pm
this is what I try to avoid. I know I can manually move the precomp in each separate composition som it would match but everytime I change the length of the compositions, I would need to adjust the whole thing again.
Miro Nauces
on Jun 23, 2017 at 4:55:45 pm
Just a quick idea - could I use some expression that sets the start of the precomp to the actual time on the main composition? This way I would not need to manually adjust it.
