H.264 in Quicktime wrapper out of Media Encoder
Rob Price
on Jun 19, 2017 at 7:34:36 pm
I know that Rule One is simply "don't do this," and usually I don't, but I'm dealing with a signage display/playback system that doesn't care what the rest of the world is doing.
What I'm trying to do is just what it sounds like: get a decent-looking .mov file with H.264 compression out of After Effects using Media Encoder.
Adobe CC 14.1.0.57 ; Mac OS 10.12.5.
File looks great at 10MBps as an .mp4, chewed to bits at the same rate (or even much higher) as an .mov. Display people insist on a file that says "H.264" when you check the Movie Inspector in Quicktime Player. They also want a very small file, so just sending them the default high-quality one is not an option, either.
Would Compressor solve this? My current donkey workaround is to remove the content from a rotten-looking H.264 .mov file and paste in the content from a decent-looking .mp4 file using Quicktime Player. Naturally this is making my head explode with anger.
Is this something that's been figured out yet?
Daniel Waldron
Re: H.264 in Quicktime wrapper out of Media Encoder
on Jun 20, 2017 at 1:19:26 am
I agree on MPEG Streamclip. Better quality Quicktime H.264 than AME in my opinion. Free download too.
Tero Ahlfors
on Jun 20, 2017 at 6:15:04 am
In addition to bit rate you'll need to set a keyframe value for the encoder if you're exporting Quicktime H264. Otherwise it'll look terrible.
Michael Szalapski
on Jun 20, 2017 at 6:28:41 pm
If you can get a decent-looking MP4 out of Adobe Media Encoder, try simply changing the file extension from MP4 to MOV. See if it works for you. I've seen that do the trick in some cases.
- The Great Szalam
Matthew Ross
on Jun 20, 2017 at 7:38:07 pm
I used to use an x264 implementation out of Compressor to achieve this (way better than Apple's H.264), but that was so long ago I do not recall how we got that particular x264 version into Compressor.
The last time I had to do this, I rendered an intermediate file out of After Effects (or Premiere or whatever), something like ProRes or like others listed in this thread, then rendered to x264 using Handbrake, then re-wrapped the file to .MOV using Quicktime Pro 7 by simply using Save As, and it would do so without re-compressing. (I do not know if Quicktime 10 lets you do this).
Yeah, it was three steps so wouldn't be good if you had to do a lot of files, but I got good looking H.264 in .MOV containers in the end.
Ron Price
on Jun 20, 2017 at 8:27:59 pm
Thanks, everybody! MPEG Streamclip did the job for me.
[Michael Szalapski] "If you can get a decent-looking MP4 out of Adobe Media Encoder, try simply changing the file extension from MP4 to MOV. See if it works for you. I've seen that do the trick in some cases."
I did that first thing, and it worked fine as far as playing back, but it changed the codec listed to AAC. It has been suggested that the venue's QC process involves checking the file in Quicktime to see if it says H.264. I didn't want to take the chance that the files would be rejected. It's a new client, and I'm trying to do this without too much back and forth or antagonizing of the venue.
[Matthew Ross] "
Yeah, it was three steps so wouldn't be good if you had to do a lot of files, but I got good looking H.264 in .MOV containers in the end."
Still better than my "make a ugly version in a H.264 .mov wrapper, open in QT, paste my nice .mp4 video in, then trim out the bad video" solution. 😳
Esben Rahbek
on Nov 16, 2017 at 10:49:46 am
I have the same problems as you, Ron. I tried MPEG Streamclip with no luck. Would you mind posting your settings?
Ron Price
on Nov 18, 2017 at 11:02:15 pm
These are the settings I used back when I did it. (It was for digital signage, which is why the dimensions are weird.) It worked fine, as I recall, but I haven't used it since. I was able to get it to work well with much lower rates as well, I believe.
If this doesn't help, post again and I'll see if I can do a test file or something...
