Reverse layer - layers do not snap to whole frame
Dennis Squadrazzino
on Jun 19, 2017 at 6:16:00 pm
Hi dear community,
i have a precompositon which is 25 fps. It just contains some text layers and two shape layers. I precomposed this layer, duplicated it and reversed the direction of this layer (layer->time-> Time reverse layer.
Now her is my problem: the reversed precomposition does not snap to whole frames. There's always a little "gap", the same which appears when trimming layers, but i did not trim the layer. See here:
11454_precompreversedprecomp.png.zip
There's also a gap at the end of the reversed precomp which is worse as it does not show the animation to the end.
See here:
I really need to solve this soon! Would love to hear some tips!
Mayber this helps: I also can not set the playhead on the last frame of the composition. Just by using a shortcut, but not with the mouse. When the playhead is positioned on the last frame, there is no picture in the preview window!
Best regards,
Dennis
