Layer Styles vs Effects & Presets
Jack Kavinsky
on Jun 19, 2017 at 4:34:14 pm
Hello,
A layerstyle (drop shadow) on a pin drop on a map , (when pin is duplicated 40+ times) takes unnecessarily long to render.
Would it be faster to use Effects & Presets> Drop Shadow ?
How are these calculated ?
Also, "Trim Paths". which is nested like a layerstyle, would this be similarly render intensive VS just drawing a path and applying Effects & Presets > Stroke ?
Regards,
Kavinsky
Walter Soyka
Re: Layer Styles vs Effects & Presets
on Jun 19, 2017 at 5:48:17 pm
[Jack Kavinsky] "A layerstyle (drop shadow) on a pin drop on a map , (when pin is duplicated 40+ times) takes unnecessarily long to render. Would it be faster to use Effects & Presets> Drop Shadow ?"
Yes, especially in the latest release, where Drop Shadow is a GPU-accelerated effect.
Walter Soyka
Jack Kavinsky
on Jun 20, 2017 at 1:58:33 am
Walter, thanks for responding.
"Yes, especially in the latest release, where Drop Shadow is a GPU-accelerated effect."
Jack Kavinsky
on Jun 20, 2017 at 2:00:03 am
Jack Kavinsky
on Jun 20, 2017 at 2:01:31 am
Memory & Multiprocessing settings i'm currently using:
