Generating Normal Map from PNG Sequence
Michael Cabral
on Jun 18, 2017 at 5:14:11 pm
Hi, I'm not exactly sure what thread to post this in, and I've gotten most of my answers in the past from this thread, so I'll post this here and maybe I can be redirected somewhere else.
Basically, I thought this would be basic. I have an avi file that I want to convert to a normal map sequence with a normal map generator. My plan was to export 300 frames (all I need is 300 frames of normal map) as a PNG sequence from after effects, then import the png sequence into a normal map generator. However, I have not been able to find a single normal map generator that supports sequences. I know this is sort of an abstract idea/procedure that isn't very common, but wondering if any of you knew of any generators that can produce normal maps from sequences or video files/know any techniques I can use to convert a 300 frame png sequence into a 300 frame normal map png sequence.
