Can't write to file (after effects scripting)
Arno Deceuninck
on Jun 18, 2017 at 4:01:21 pm
I have this code:
var exportDurationFile = new File;
exportDurationFile = exportDurationFile.saveDlg ("Choose your duration export location", "Text File:*.txt");
exportDurationFile.open("w");
$.writeln("opened for writing");
exportDurationFile.encoding = "UTF-8";
$.writeln("Encoding set to UTF-8");
exportDurationFile.write("test");
$.writeln("test written to it");
exportDurationFile.close();
$.writeln("file closed");
$.writeln("export succesfully");
But it doesn't write anything to the file, this is the console output:
Select output file
opened for writing
Does anyone know what I'm doing wrong?
Walter Soyka
Re: Can't write to file (after effects scripting)
on Jun 19, 2017 at 2:24:08 pm
Your code is fine. You have to make sure you've enabled "Allow Scripts to Write to Files and Access Network" in Ae's general preferences.
Walter Soyka
Arno Deceuninck
on Jun 19, 2017 at 6:06:47 pm
