How do I do this effect?
Danel Martinez
on Jun 18, 2017 at 3:40:00 am
Hi, I'm new to this forum, I wanted to know how I make these effects.
Effect 1:
Effect 2: White Aura
Leopoldo Perizzolo
Re: How do I do this effect?
on Aug 26, 2017 at 4:14:49 pm
Maybe I'm a bit late....anyway:
1st effect:
- go to Layer -> Autotracer -> Enable preview -> mess around with the values while looking at the comp and seek for the creation of a mask all around the hand, keeping the "minimum area" almost as high as possible (to avoid double-masks)
- apply VC saber on the newly created layer with the mask (it's a free plugin) -> select the source as the mask path on the effect -> refine other parameters as needed; you should get a nice glow all around the hand
- since you have the mask layer, duplicate that and a copy of the hand footage, then set the hand layer as alpha (or alpha-inverted) track matte of the mask layer; this way you can control the hand separately from the background and apply an exposure and glow effect.
2nd effect:
- do basically the same thing but this time apply a more subtle exposure and glow to the layer with the person.
Leopy
