MXF Codec Question and Workflow Recommendation
Paul Winterton
on Jun 14, 2017 at 10:05:04 pm
A client has asked me to import a specific file format, XF-AVC intra 10 bit 4:2:2 @3840x2160, add VFX, and return the same format back to them.
I use After Effects (2017) PC and AME (2017) PC and I can't find the specific codec to do as requested.
I'd like to know what a more experienced person would do, as I believe that the desired codec is not yet available for AAE or AME for PC.
Ultimately the client is worried about altered color space if I deliver a different format and/or bit rate. Is there a method to follow to alleviate the problem.
What would you do?
Thank you for reading and replying.
Tero Ahlfors
Re: MXF Codec Question and Workflow Recommendation
on Jun 15, 2017 at 4:10:01 am
As far as I know that specific format/codec is for in-camera recording only. You can read it but you can't export in the same format.
Paul Winterton
on Jun 15, 2017 at 4:59:33 pm
Thank you for the insight.
The background is: the client is a Mac-based production facility and previously they have sent me ProRes 422 files, but because my suite is PC-based I can't return ProRes files. AFAIK the ProRes export codec is (still) not available for PC. I can read, but I can't write ProRes files.
I either encode MOV with the Animation codec, or use MP4 with a very high bitrate to deliver files back to the client. There is a color shift in both formats.
The client is trying to find a way that they can deliver a format that won't be degraded or changed and so that they could do (final) color grading consistently throughout their show. Hence, they were asking if I could accept and return the MXF camera format.
I'm open to any suggestions that would solve this issue.
Thanks again for reading and replying.
