How to achieve the combination of CC Time Blend and Transparency
Mehdi Rafeie
on Jun 14, 2017 at 5:27:28 am
Hi guys,
I am working on a scientific project that entails tracking of cells passing through a bifurcation. A couple of years ago, Kalle Kannisto came up with a perfect solution to my problem of indicating the trajectories of particles flowing in a microchannel (please have a look at it here). Now, I need to do the same with the difference that the trajectories of cells/particles are expected to appear translucent so that the more cells follow the same path, the more opaque it should look.
appreciate your help
Walter Soyka
Re: How to achieve the combination of CC Time Blend and Transparency
on Jun 14, 2017 at 3:12:33 pm
You need to change the order of operations you're doing here. You were doing a time blend, then the difference; now you need to do difference first, then time blend.
First, create the precomp that shows the difference between the movie and the "clean plate" -- that is, a frame with no visible cells. Then, back in your main comp, use Echo with a lower starting intensity and an Add blend operator to let the brightness values accumulate over time.
Here's a quick and dirty example of this, from your previous upload:
Walter Soyka
Mehdi Rafeie
on Jun 15, 2017 at 3:16:36 am
Thanks a lot for your reply, Walter. That is indeed what I am looking after. However, I could not achieve the same result. Could you please elaborate further on your solution?
To do the Difference before the Time Blend, I first imported my new video file as well as a frame representing the clean look of the microchannel into a comp. I then set the blend mode of the video layer to Difference and converted these two layers into a pre-comp. Next, I applied the Time Blend effect on the pre-comp by setting the Transfer parameter to Lighten and Accumulation to 100%. Finally, as you instructed, I applied Echo and tried to play around with its variables with no success.
Your help is highly appreciated
