Solid outside visible field
Daniele Crespini
on Jun 13, 2017 at 10:44:08 am
This is my aim:
I created 2 solids (effected with Trapcode Form)They are both 1920X1080. I created a camera. The 1st solid is filmed from front from the camera since the beginning. The second solid is aligned on the right of the first one and I don't see it because it's outside visible field. I want to move the camera ( and rotate it) to watch both solids from the left side, but the second solid is never visible.
Sorry for my english
Daniele
Walter Soyka
Re: Solid outside visible field
on Jun 14, 2017 at 2:08:35 pm
Can you back up a little bit and describe what you want to accomplish and why you are using two solid layers?
Generally, with camera-aware effects like Form, you only want 2D solid layers that are sized to and centered in the comp.
Walter Soyka
