What is the difference between X-spline and bezier layer in Mocha?
Guillaume Jaecques
on Jun 12, 2017 at 8:19:29 am
I'm trying to figure out what the benefits and differences are between X-spline and bezier layers in Mocha, but just can't figure out when to use what. Somebody that can give a quick idea of the difference of these two? It would help me a lot!
Mark Whitney
Re: What is the difference between X-spline and bezier layer in Mocha?
on Jun 12, 2017 at 4:36:20 pm
Easiest way to understand them is to simply make one of each and play around with the handles.
The X-splines will be easier to use in most cases. The handles will always mirror each other. Since one is most often just making a rough shape in Mocha, that sort of control is quicker to work with.
Bezier's can "break" the curve with independent handle control. If you're trying to make a crescent moon shape for example, then that's what you'd use.
Roei Tzoref
on Jun 12, 2017 at 5:38:26 pm
As a rule of thumb: X for organic shapes and most of your tracking needs, B for percise geometric Rotoscoping.
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
