Exporting Data from Mocha Pro to AE
Tristan Nieto
on Jun 9, 2017 at 2:50:30 pm
Hi there,
Trying to do a stabilise. The initial track works well, Mocha renders a lovely version of the stabilised shot that looks great, but I can't seem to get any usable data out of Mocha and into AE.
The exported data doesn't have any anchor point information (regardless of whether "invert" is ticked), but I'm not convinced it would fix the problem even if the data was there, as the position doesn't seem to correlate to anything that's being tracked either.
Any suggestions? I'm working with largish files - a 3.2K exr sequence. Running Mocha 5.2.0
Thanks.
Roei Tzoref
Re: Exporting Data from Mocha Pro to AE
on Jun 10, 2017 at 11:19:48 pm
the problem usually is misinterpretation of the frame/duration in either Mocha or Ae. make sure the composition settings and mocha clip settings match. also make sure that your mocha in/out points and Ae Composition layer in/out point match. if his does not work for you, maybe you could share some screenshots or better yet - a video capture so we can see where is the issue
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
