Trapcode Form - Pixel Perfect Grids
andy nick
on May 31, 2017 at 6:51:20 pm
Hey all,
I'm trying to use Form to replicate a pixel-perfect layer map.
My comp size is small (150x150) and my layer map is perfect black and white pixels. When I use Form to make a single plane of particles, I expect to see a 1 to 1 perfect replica of my layer map.
Instead, my Form output has a sharp "epicenter" (bottom-right), and an increasingly blurry radius. (Note: it appears to be coming back into focus on the top left.)
Here's a screenshot. Layer Map (jpg) on the left, output from Trapcode Form on the right.
I'm using square particles, no camera. A zip containing the CC2017 AEP and JPG image map are available at the link below:
https://www.dropbox.com/s/s8ch83wyq1xlrvk/TrapcodeForm_PixelPerfect_test_01...
If you can ID the cause of the blurriness, I'd be very grateful.
Thanks in advance!
