Can you believe this? Timeline issue...
Syed Iqbal
on May 29, 2017 at 3:07:11 pm
Hi folks,
Never experienced this before and tried to Google it but could not find a clue. I have 958 text layers but the first few lines even though exist there but I cannot see their in and out points on timeline. Below image is self explanatory.
Could someone please rescue ASAP.
Walter Soyka
Re: Can you believe this? Timeline issue...
on May 29, 2017 at 4:05:15 pm
If you use the shy layer switch to temporarily hide some of the layers from the timeline, does that work around your issue?
Walter Soyka
Syed Iqbal
on May 30, 2017 at 3:25:47 pm
Hi Walter,
Thanks for your tip. I will give it a try one more time. Do you think when you have so many layers, more than 900 of them, you might experience this issue? Is there any limitation on number of layers you can keep visible on timeline?
Again, the playback was showing these layers i composition and selecting a hidden (seemingly) layer and using in and out point shortcut keys were also working fine, the only thing I found irritating was not being able to see it's normal behavior.
Thanks again for your time.
Syed
Walter Soyka
on May 31, 2017 at 3:27:34 am
The total size of the contents of the timeline panel is subject to a vertical limit of about 32,000 pixels. More than that, stuff gets funky.
Walter Soyka
