Change default Keyframe Velocity?
Raine Vivian
on May 25, 2017 at 9:33:42 pm
Hey guys!
So in motion graphics am am constantly pressing F9 on keyframes for easy ease, then edits the Keyframe velocity to 80% incoming and out going. I do this to almost EVERY key frame.... In that light it would have me a TON of time if I could somehow change the default % (33.3) to be 80% after setting easy ease... Man... If there's a way to do this.... I'll give you a $100000 dollars, because it will same me SOOOO many damn clicks. Any idea's?
Cheers guys!
-Raine Vivian
http://www.rainevivian.net
http://www.seaboundesign.com
Cassius Marques
Re: Change default Keyframe Velocity?
on May 26, 2017 at 9:07:35 pm
You can't change the default value.
What you can do is create a script that sets the influence to 80%/80% and add a shortcut to it replacing the f9 key.
Cassius Marques
http://www.zapfilmes.com
