Numbers changes between two set of exactly same linear keyframes ( copy pasted )
kewei du
on May 25, 2017 at 4:00:12 pm
Hey guys,
I am running into this weird issue which is. I copied and pasted the keyframes from each other, and it's linear keyframes,
somehow, the numbers change in between of those keyframes, so there are some unwanted motions. Please Help!
Dave LaRonde
Re: Numbers changes between two set of exactly same linear keyframes ( copy pasted )
on May 25, 2017 at 5:05:02 pm
It sounds like you want a layer to hold still. Right-click on the INCOMING keyframe, and use the Toggle Hold Keyframe command. That's it.
As AE encounters the OUTGOING keyframe, the animation will resume.
Dave LaRonde
Promotion Producer
