Grid pixelates after rendered
Søren Wind
on May 19, 2017 at 5:21:14 pm
I have a problem with After Effects where the video always pixelates at a certain point. It doesn't happen when I preview it in the program. I always choose High Bitrate settings when rendering. Unfortunately I don't have a lot of knowledge about rendering options.
I have two screenshots showing the problem.
Michael Szalapski
Re: Grid pixelates after rendered
on May 19, 2017 at 6:53:13 pm
If you are using AE's render queue, what are your render settings and output module settings?
If you are sending your render to AME, what are your settings there?
- The Great Szalam
Søren Wind
on May 19, 2017 at 8:58:53 pm
I'm sending my render to AME. I have the settings in the picture below. Hope it helps.
Dave LaRonde
on May 19, 2017 at 10:15:16 pm
You could try 2-pass VBR in those settings, but I don't know if it will help much. The H.264 codec is notorious for its failure to cleanly encode sharply-defined edges, and you have a lot of them.
Please tell us how this will be used, and if you're part of a production pipeline, the individual who will use the animation next.
Dave LaRonde
Promotion Producer
Søren Wind
on May 20, 2017 at 12:01:56 pm
2-pass VBR seems to do the job! Thank you very much.
