Reverse linear wipe expression
Rory Flynn
on May 17, 2017 at 9:59:21 pm
I am trying to drive a linear wipe transition with the y rotation on another layer. So I have linked them using the pick whip. This works however it animates from 0-100%. I need it to animate from 100-0%. Is there something I can put in the expression to reverse it?
Walter Soyka
Re: Reverse linear wipe expression
on May 18, 2017 at 3:22:42 am
linear(x, 0, 100, 100, 0);
Replace x with your pick-whipped property.
In English, this code says, "as x goes from 0 to 100, return a range from 100 to 0."
Walter Soyka
Rory Flynn
on May 18, 2017 at 10:10:48 am
That's perfect. Thanks Walter.
