After effects adding noise on render.
James Graham
on May 15, 2017 at 9:20:50 am
Hey everyone.
I currently have an issue with after effects adding noise to my animation that isn't there. I'm using several PNG layers with transparency and a camera in a 3d space to create the effect I want however as the camera moves its rendering noise over the animation that causes it to flicker. The noise is fairly fixed to specific frames and generally happens as the camera moves over the animation.
There are no effects applied it is all organic layers the camera is the only element creating any part of a look. Any Ideas?
(I'm using the latest version of Adobe CC and working on a Late 2013 Mac Pro 3Ghz 8core E5, 64GB of RAM, D500 running 10.12.3)
Ive added two screen shots of frames where the noise is and where it isn't.
Thanks All
James Graham
Re: After effects adding noise on render.
on May 15, 2017 at 1:52:03 pm
