After Effects CC 2017 Not Responding
Tyler LLink
on May 11, 2017 at 1:40:51 am
So I have just now downloaded After Effects CC 2017, (mainly for the use of the Lumetri Scopes feature) and whenever I attempt to change anything in the composition, any existing layer, effect, or if I even just move the After Effects Window around on my desktop, it will immediately begin to not respond, and then forward me to close the program. I can load up After Effects just fine, but when I edit anything in the slightest, it does not respond.
Side note; I had After Effects CC 2015 before CC 2017 and it worked just fine.
Walter Soyka
Re: After Effects CC 2017 Not Responding
on May 11, 2017 at 11:11:16 am
Inexplicable Problem Troubleshooting Step #1 for After Effects is always resetting your preferences. Launch Ae, and hold Ctrl+Alt+Shift (Windows) or Command+Option+Shift (Mac OS) while the application is starting.
Walter Soyka
Tyler LLink
on May 11, 2017 at 11:13:07 pm
I just now tried this solution, it did not work.
Walter Soyka
on May 12, 2017 at 9:46:31 am
Bummer. I'd also suggest uninstalling and re-installing Ae, because what you are seeing is definitely not normal.
For other clues as to what might be going wrong, are you on a Mac or on Windows?
Walter Soyka
Tyler LLink
on May 12, 2017 at 7:26:49 pm
I have already reinstalled once, no fix. I am on Windows 7... does CC 2017 happen to only be compatible with Windows 10?
Walter Soyka
on May 16, 2017 at 9:56:17 am
If you uncheck Edit > Preferences > Display > Hardware Accelerate Composition, Layer, and Footage Panels, does that eliminate the crashing?
Walter Soyka
Tyler LLink
on May 22, 2017 at 12:19:30 am
Yes it did! Thank you so much
Walter Soyka
on May 22, 2017 at 12:31:36 am
Cool. What GPU are you using? Maybe try updating your graphics card drivers and see if that enables you to keep the hardware acceleration setting checked?
Walter Soyka
