Glyphs?
Ward DeMartino
Glyphs?
on May 10, 2017 at 10:04:20 pm
hi, n00b here...wondering if you can access a glyphs panel within AE for types with glyphs available? I've been able to access the glyphs within other Adobe programs, but I can't find where to access them within AE. Is there a place to find them and if not, why not?
Thanks a ton!
ward
Dave LaRonde
Re: Glyphs?
on May 10, 2017 at 10:56:39 pm
Sorry, but you can't, because AE's text functions aren't capable of doing it. You just have to select the typeface and type.
Dave LaRonde
Promotion Producer
Walter Soyka
Re: Glyphs?
on May 11, 2017 at 11:23:13 am
This bums me out, too. I'm going to file a feature request and I suggest you do the same. As a workaround, I put the glyph in a text object inside another Adobe app, then copy and paste that text into my Ae text layer.
Walter Soyka
Ward DeMartino
Re: Glyphs?
on May 11, 2017 at 5:55:04 pm
Thanks Dave and Walter! I will also file a feature request. It's odd it's not an option. Appreciate the replies!
Seth Taylor
Re: Glyphs?
on Dec 13, 2018 at 7:44:42 pm
Old thread, but here's a solution I just utilized.
Type the text in Adobe Illustrator, insert the alternate glyph in AI, then copy that text and paste into a text layer in After Effects. It just worked for me, I hope it can help you.
Seth Taylor
:: stotion.com Branding & UX Design
:: Stotion creates products and designs assets that build strategic value for clients and users
Kalleheikki Kannisto
Re: Glyphs?
on Dec 15, 2018 at 4:33:38 pm
On Windows, the built-in CharMap utility is a fast and easy option as well.
Senior Graphic Designer
