Particular: Emit Particles to specific Points
ngo truong an
on May 8, 2017 at 9:36:15 pm
Hello Everyone, is it in Particular possible, to emit the Particles from a Logo to specific Points?
Kevin Camp
Re: Particular: Emit Particles to specific Points
on May 9, 2017 at 4:43:58 pm
not exactly... but you may be able to manipulate motion paths to control the particles they move to a certain area...
here's one tutorial on motion paths, but there are others:
Foam allows control of the motion of particles using a grayscale map. so you might be able to manipulate that effect to get what you want... here's a really old tutorial on using 'flow maps' in foam: http://www.creativemac.com/2004/02_feb/tutorials/positiveluv.htm
it's not a 3d particle system, so it may not work for what you need....
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
ngo truong an
on May 23, 2017 at 7:03:14 pm
Sorry for the late reply Kevin, it was so stressful at work, thank you for your Advice. Greetings An
Steven Perry
on May 9, 2017 at 6:27:17 pm
I think if you combine layers... you could trick the effect
1. A particle layer that emits particles from logo to a cloud
2. A particle layer that emits particles from points to same cloud.
3. Pre-comp and time reverse the layer in step 2.
Looking up how to make a perfect particle loop may help to understand the concept.
ngo truong an
on May 23, 2017 at 7:11:32 pm
Hi Steven, sorry for my late reply, it was so stressful at work, this is really helpfull. I think this could work.
I will try this out, when it will be less stressfull.
Thanks and greetings An.
