shape/stroke animation with continuesly blend effect?
Mátyás Bosnyák
on May 7, 2017 at 10:13:04 am
Hy guys!
I have an idea, what i'm trying to do in the days, but i can't figure out.
I want to create an animation with one shape (but the stroke is the point), wich behave like a loop.
I want to blend this animation with a greater circle, so the steps between the blend marks have to move.
The visual is like a topographic map, but the looped transition should be smooth, the space between the contours like equal.
All suggestions are welcome! ❤
Best whishes,
motyodlee
Greg Gesch
Re: shape/stroke animation with continuesly blend effect?
on May 7, 2017 at 11:40:13 pm
Hi Matayas, you could use the Liquify effect on concentric circles (which could be created by using the Radio Waves effect and saving as an image).
