Source Text property
Syed Iqbal
on May 6, 2017 at 12:47:19 pm
Hi
From AE scripting guide I got this snippet:
var myTextDocument = newTextDocument("HappyCake");
myTextLayer.property("SourceText").setValue(myTextDocument);
In the above example, the code is inking sourceText value to an external text file named "HappyCake".
Is there any way to direct it to use clipboard or text copied in memory as layer's sourceText?
Syed
Walter Soyka
Re: Source Text property
on May 6, 2017 at 5:44:14 pm
[Syed Iqbal] "Is there any way to direct it to use clipboard or text copied in memory as layer's sourceText?"
ExtendScript doesn't have a way to get at clipboard data. You can work around this in Ae with system.callSystem() and some clipboard-related command line utilities, like clip.exe and paste.exe on Windows (paste available separately!), or pbcopy and pbpaste on macOS.
Walter Soyka
