i lose the 3D references if I add an effect layer 2D between a 3D layers
nth lat
on May 5, 2017 at 1:39:28 pm
Hello I have a problem in after effects, i lose the 3D references if I add an effect layer 2D between a 3D layers
I do not want to precomp
Is there a solution to keep my references of "Z" of my 3D layers by adding an effect layer? (Because at the moment the layer of effect cancels any info of "Z" and takes into account only the hierarchy of the layers.
Thank you for your answers
Dave LaRonde
Re: i lose the 3D references if I add an effect layer 2D between a 3D layers
on May 5, 2017 at 2:38:42 pm
No. You can't do it. After Effects, while it allows 2D layers between 3D layers, will indeed lose 3D references. You'll have to figure out another way to do what you want.
Dave LaRonde
Promotion Producer
