How do I create agent carter portal
Steve Winyard
on May 5, 2017 at 10:59:45 am
How do I create a portal the same as featured in season 2 of agent carter:
Thanks.
Tudor "Ted" Jelescu
Re: How do I create agent carter portal
on May 5, 2017 at 1:15:16 pm
if you want to stick to AE then you can either use Element 3d or C4D to import and animated the 3d objects that are sucked in the portal. The portal itself can be created several ways - check out videocopilot for some great ideas in tutorials and take a look at the Shockwave pack that has a bunch of particle animations that you could use of the portal.
Trapcode Particular is another great particle system that can be used.
Here are a few tutorials:
http://www.videocopilot.net/tutorials/the_portal/
http://www.redgiant.com/tutorial/dr-strange-portal/
Tudor "Ted" Jelescu
Senior VFX Artist
