does 23.98 drop frames in AE?
Charlie Canfield
on May 4, 2017 at 1:46:31 am
i have some 23.98 footage, brought it into a 23.98 comp.
i created several single-frame sync pops at different spots with solids and the tone effect (i'm chopping up the footage into scenes and want syncs head and tail on all of them).
upon rendering as quicktime movies (i tried h264, apple pro res proxy and animation no compression) and even a png sequence, many of these sync pops disappeared; although which syncs appeared/disappeared varied.
not until i created a 24 fps comp and interpreted the footage as 24 did all of the single-frame syncs pops appear correctly.
ideas?
Walter Soyka
Re: does 23.98 drop frames in AE?
on May 4, 2017 at 2:31:46 am
You shouldn't be seeing any dropped frames. Double-check your frame rate, maybe? 23.98 is really 23.978.
Walter Soyka
Bouke Vahl
on May 4, 2017 at 10:10:49 am
Walter,
It's in fact 23.976 !
(24 & 1000 / 1001)
Bouke
http://www.videotoolshed.com
Walter Soyka
on May 4, 2017 at 11:36:48 am
Yes, of course! Please ignore my braino above (sadly, not quite a typo). Thanks for the correction, Bouke.
Walter Soyka
