Set keyframe to have incoming hold?
Harry Hoag
on May 1, 2017 at 9:32:09 am
Hello!
I think this is trickier than is sounds. I need to set a bunch of keyframes to have an incoming hold. If you right click on keyframes and click "toggle hold" it only holds the out going animation from that keyframe. If you then create subsequent keyframes, afx creates frames that are held on in and out (a fully square looking frame icon). Is there a way to drag select a load of keyframes and manually set their incoming interpolation to hold?
Thanks ☺
FYI, the reason I need to to this is I'm doing a big character animation sequence and I need to animate earlier in the timeline than some other animation. So I want the earlier animation not to move to the next keyframes while I'm working on it (if that makes any sense)
Dave LaRonde
Re: Set keyframe to have incoming hold?
on May 1, 2017 at 2:02:01 pm
It's easier than you think! Highlight the incoming keyframe. Right-click on it and select Toggle HOLD keyframe. That's it! Pretty easy, huh?
They big thing is to get all the keyframe values right BEFORE you use this trick. That way, the image won't jump when AE encounters the outgoing keyframe.
You'll still have the ability to move keyframes on the timeline for timing purposes.
Dave LaRonde
Promotion Producer
Harry Hoag
on May 1, 2017 at 2:22:43 pm
Hi Dave, thanks for the reply although I think you may have missed a key (pun intended) part of my problem. When you hit toggle hold it only holds the outgoing animation, is there a way to convert a keyframe to a hold in both directions?
Dave LaRonde
on May 1, 2017 at 5:32:47 pm
You don't have to do that.
When AE encounters a Hold keyframe in the timeline, it freezes the keyframe's values until it encounters another keyframe in the animated parameter... at which point the animation resumes.
When resuming the animation, the outgoing keyframe can be any kind. Linear, Bezier... what have you. If it's another Hold keyframe, the change to the new value -- if any -- is instantaneous.
You don't have to mess up your painstakingly-created project to confirm this. Just make a new project with a new comp and do something dead simple like playing around with position animation. See how it works.
After you've built up your experience and confidence with Hold keyframes, you'll be fine.
Dave LaRonde
Promotion Producer
Mathias Möhl
on Dec 30, 2017 at 12:40:35 pm
I think Harry is right that there are situations where keyframes with incoming hold make a lot of sense.
Note: incoming hold means that the value of the keyframe is hold BEFORE the actual keyframe, not after it.
If I see it correctly, using incoming hold is actually the only way to create truly abrupt changes.
Harry Hoag
on Dec 30, 2017 at 2:36:24 pm
Yes! I kind of gave up on this as it's quite hard to explain and I knew there was no answer really, but that is exactly it.
There is no way to manually create an INCOMING hold keyframe. After effects will make one if you're making a keyframe after a hold frame, but there's no way to MAKE one. For character animation it would be really handy sometimes. There may be a feature I'm not aware of but seems like something adobe would have to add.
Amy Young
on Jan 31, 2019 at 5:34:29 pm
I somehow have the "incoming hold" on some keyframes, but I can't replicate it or even guess what my steps were. Very puzzling. Toggling the keyframes, deleting and replacing, putting different types of keyframes in front before creating...nothing I do makes a "incoming hold," on purpose or by accident.
Dave LaRonde
on Jan 31, 2019 at 7:05:44 pm
It looks like they're ALL hold keyframes. You may want to start over again. Select all of them, right-click on one of them, an change them all to Linear. Then right-click on the incoming keyframes and use the toggle hold keyframe command. This should sort things out.
Dave LaRonde
Promotion Producer
Mathias Möhl
on Jan 31, 2019 at 7:40:15 pm
In contrast to the user interface of Ae, scripts can actually set the keyframe interpolation for in and out independently.
I haven't tried it, but this script seems to offer a nice implementation:
https://gumroad.com/l/behold
Harry Hoag
on Feb 3, 2019 at 2:22:04 pm
Ahh nice yes this looks like the solution, I'll give it a go, thanks Mathias! It's a hard one to explain, searching for a solution is quite tricky.
