Feathering a layer mask makes a hard edge, not an opaque gradient
William Hickox
on Apr 29, 2017 at 4:03:58 am
I probably worded the subject horribly, but this screenshot explains what I am talking about https://gyazo.com/4995e50993a789fbaa4826c0f62b71b1 why does it not "feather" and instead creates a hard edge.
Greg Gesch
Re: Feathering a layer mask makes a hard edge, not an opaque gradient
on May 1, 2017 at 12:46:49 am
Hi William. I suspect your problem is that you have a small mask area and a massive feathering of 635 pixels. Try pulling the feathering way, way back and increasing the Mask Expansion to see if that gives you what you need.
William Hickox
on May 1, 2017 at 1:06:10 am
https://gyazo.com/0309931bf226b1bb7de1ba2f9ac1d4df It still does it no matter the size of the mask feather.
To add more information, it is one mask on a solid that has the fractal noise effect on it.
Harry Hoag
on May 1, 2017 at 10:46:37 am
might be the effect that's causing that. Try putting the mask on a solid layer above the layer with the effect on it. Then use the solid with the mask as an alpha track matte.
