compress transformations acting as if it is on when it is not selected.
Jeremy Dance
on Apr 28, 2017 at 5:55:29 pm
I am using AE 2017 and I have a composition rendered with the Cinema 4D option because there is some curved geometry in it.
This composition (I will call it the 3D composition) resides in another composition that is rendered using the classic 3D option (which I will call the 2D composition).
For some reason, my 3D comp is acting as if the compressed transformations button is selected when it is not.
Side note, just 10 minutes ago it was working as expected, with my 3D layer rendering as a flat composition. The only thing I edited was the null my camera was attached to in my 3D layer. Then when the camera movement looked good I jumped back into my 2D scene and my 3D comp started acting like the compress transformation button was pressed.
Any ideas?
