Apply Blending mode with slider?
Duca Simone Luchini
on Apr 28, 2017 at 7:53:38 am
Hi everybody,
there is a way to use only e certain percentage of blending mode, meybe using a slider?
I mean, there are many effects which are a slider to set up a percentage of fx to apply or/and e percentage of blending mode (of the effect).
But in AE, unfortunately..., blending mode can be 100 % or nothing applied.
Suggestions?
Walter Soyka
Re: Apply Blending mode with slider?
on Apr 28, 2017 at 2:24:25 pm
1) Duplicate the layer, set its blend mode as you like, and adjust its Opacity property.
2) Use the CC Composite effect.
Walter Soyka
Duca Simone Luchini
on Apr 29, 2017 at 7:20:24 am
Many thanks Walter,
so, if I've rightly understand these are two alternatives?
I mean, you can use Opacity on the duplicated layer OR you can use CC Composite effect?
Walter Soyka
on Apr 29, 2017 at 8:57:00 am
Yes, I proposed two ambiguously-numbered alternatives.
Walter Soyka
