Long shadow
Chris Brady
Long shadow
on Apr 26, 2017 at 11:58:09 am
I am trying to re-create the style of long shadow seen in the video below:
https://vimeo.com/174142915
I need to supply the final After Effects file to the client so can't use any plugins they won't have, unless I can apply the Expression Universalizer to the final file before supplying.
I have tried the Long Shadow plugin. However this does not give me the same level of blurriness that is shown in the example video.
Even if it is a long winded manual way of applying this effect, what would be the best way of doing so? Any ideas would be greatly appreciated.
Richard Garabedain
Re: Long shadow
on Apr 26, 2017 at 2:56:52 pm
Its probably an actual shadow created by an actual light. with a high difuusion shadow. Might have to be in ray trace 3d mode under composition settings
