Ram Preview not playing at the current Time Indicator
Daryl Ochave
on Apr 19, 2017 at 10:47:21 am
Hello, this is my first time posting here but I do visit this site often when I encounter problems in After Effects.
Everything is just fine when suddenly the ram preview isn't working as its used to be. When I move the current Time indicator at a specific keyframe, the preview plays at the beginning of the composition (or at the beginning of the work area).
Here is a video of the problem:
https://media.giphy.com/media/5J5byEQ0K7noI/giphy.gif
https://giphy.com/gifs/5J5byEQ0K7noI/html5
EDIT: Turns out I altered some of the RAM preview settings. Can remove this thread? I solve the problem myself :)
Xavier Paredes
Re: Ram Preview not playing at the current Time Indicator
on Oct 26, 2017 at 12:17:09 pm
@Daryl: I'm having this same problem. When I do a RAM preview the current time indicator does not move.
What exactly did you do to fix it?
This problem started happening after I updated to MacOS High Sierra. I'm running After Effects CS6.
Xavier
Daryl Ochave
on Oct 27, 2017 at 12:08:34 am
Just change the hotkeys of RAM preview, test it, then revert it back to the default hotkey.
Works like a charm for me :)
Xavier Paredes
on Oct 30, 2017 at 3:04:56 am
Unfortunately I had to downgrade back to MacOS Sierra because After Effects CS 6 was literally freezing MacOS High Sierra. Thanks for the reply though!
Xavier
