New to rotoscoping
Scott DeRuby
New to rotoscoping
on Apr 19, 2017 at 2:08:42 am
I have a small character that I'm trying to rotoscope out of some footage I recorded with OBS in League of Legends. If that all means nothing to you, it's fine, regardless I'm rotoscoping about 15 seconds of footage at 60 fps with the rotoscoping tool. The issue I'm running into is that I'm literally having to go into every frame and correct something because it's not tracking very well with just the software. I assume this is because the background and character are not super distinct from each other.
Also, I've been at it for about 3 or so hours and I'm on frame 126, so I'm 2 seconds and 6 frames in, and I have 1065 strokes. It's starting to slow down my computer and I have a brand new desktop that I built myself for video editing. If it's slowing it down around 2 seconds in, I can't imagine what it'll do at 10 seconds or the full 15. So, I feel like I'm doing something wrong.
Attached is a screenshot for reference.
Tudor "Ted" Jelescu
Re: New to rotoscoping
on Apr 19, 2017 at 8:51:10 am
Rotoscoping is a slow painful process. I would not use the Roto brush though for your situation, rather masks with splines built on various parts of the character - one for the bulk of the body, and a few others for arms, legs...etc. Much lighter on processing and more effective in your case.
Tudor "Ted" Jelescu
Senior VFX Artist
Scott DeRuby
on Apr 21, 2017 at 3:52:50 am
Thanks, I know this is a newbie question. How many would you expect to use? One for each hand, one for each foot, one for the body, one for the staff, and maybe one for the hat? Thanks for your help.
Tudor "Ted" Jelescu
on Apr 21, 2017 at 8:41:29 am
You need to analyze your subject and see what changes shape and/or position in a significant way and what can be grouped together in one shape. Use the least amount possible but balance that out with making sure that what you group together and create one shape for does not require that you add or subtract spline points as you animate the masks.
Tudor "Ted" Jelescu
Senior VFX Artist
Remus Hosu
on Jul 11, 2017 at 9:32:07 pm
Try the new refine edge tool in AE, it will save you a LOT of time. There's a tutorial on how to do it here:
https://bluefx.net/advanced-rotoscoping-using-refine-edge
http://bluefx.net
Richard Garabedain
on Jul 11, 2017 at 9:36:17 pm
isnt there a level thats a bit more solid colored? Also its a game so your characters walk cycle should technically be by itself somewhere already...am I right about this?
